case 1960's tractor model ?????
Homer T Salisbu
01-31-2008 09:30:23
third party image
Hope someone can tell me what model this tractor is ect.
Homer T Salisbury
02-01-2008 10:32:44
 Re: case 1960's tractor model ????? in reply to Homer T Salisbury, 01-31-2008 09:30:23
Tractor engine sr# has a 2 stamped over a 1. reads 214R01009. there is a casting number on same side toward the front G2000.Axle is a straight bottom I beam slightly tapered on the top. rear rims are 24" lift arms are heavy eagle claw quick connect. thank you for all your help.HT
Joe (Wa)
02-01-2008 11:32:46
 Re: case 1960's tractor model ????? in reply to Homer T Salisbury, 02-01-2008 10:32:44
Well, that isn't an engine serial nr or block casting nr I would expect to see on 148 engine in a 300B, doesn't mean it isn't though.
The fixed rear tread and an I beam front makes it a utiliy tractor not an Ag. Your gauges are separate not in a single cluster right? Doesn't look big enough for a 510B or 610B, I am leaning more toward 210B with a 126 cid engine.
I gave away my 200B parts book, maybe someone who has one can check that G2000 block casting nr. Assuming the the engine is original, of course.
Joe
Dennis/Ohio
02-08-2008 22:45:09
 Re: case 1960's tractor model ????? in reply to Joe (Wa), 02-01-2008 11:32:46
Hi Joe,
I have a 200B parts book. Shows part# G1270. Description: Block-cylinder (Use G11560 or G10501)
Does that help?
Best wishes, Dennis..... .
Homer T Salisbury
02-01-2008 16:37:56
I was leaning toward a 210B myself but I was told they only made about 360 of them. As for the motor it has a hole in it the size of a grapefruit where a rod let loose. I was also told the tractor was original with the exception of the tires and the fenders. I guess the only thing to do is part it out on ebay. I have a 140 IH tractor that is a solid runner for now. I knew I should have stuck with my old Fords.(the 600 series 134 red tiger is my favorite) Thanks for all your help. HT
Joe (Wa)
02-01-2008 22:54:12
 Re: case 1960's tractor model ????? in reply to Homer T Salisbury, 02-01-2008 16:37:56
Ahaaa man, ya come on this haloed forum with all us rabid Case fanatics and praise one them crummy dorFs. Sheeeeesh!
Don�t worry about that insignificant little grapefruit size hole in the block. All ya need is baling wire on that loose rod and some duck tape on the block and that little tractor will out pull any 2 dorFs, even with them girlie tuff tires on the back.
Ya deserve a swift kick in the shin, lucky for you Ma hid my walker or I�d..... ..
Eldo case
02-01-2008 07:54:54
Not a 211b they don"t have fenders that go to the running boards, just small clam shell type. It looks like a 311b to me.
Joe (Wa)
02-01-2008 10:14:00
 Re: case 1960's tractor model ????? in reply to Eldo case, 02-01-2008 07:54:54
Yabbut, that looks like a tierod underneath the radius rod. If so makes it a fixed front or an adjustable I beam axle. Be a 310B utility if 300B series.
Joe
Eldo case
02-01-2008 07:54:46
Joe (Wa)
01-31-2008 11:31:53
Looks like triple range. 200B, 300B? If it still exists, model/serial nr tag should be on left side of tractor on steering cowl.
If tag is missing check below dipstick for block casting nr and above the starter for engine serial nr stamped into the block.
Joe
bradley martin
01-31-2008 10:00:38
Looks like a 300B, mfg. in "58 &"59.
