6volt charging system
MattC
01-30-2008 15:42:31
I'm having an issue w/ a 48 sc. had the generator rebuilt a few years ago, but finally have the tractor up and running. But for some reason I don't think it's charging my battery back up. I guess my questions are when the battery is disconnected and the tractor running shouldn't I be see voltage leaving the generator? I don't. And the tractor still runs fine. But with the battery connected i see 6 volts leaving. Is there something i need to do? I've read all the past articles on charging systems here on this forum but can't seem to figure it out. Any advise would be great.
Walt Davies
01-30-2008 17:40:16
 Re: 6volt charging system in reply to MattC, 01-30-2008 15:42:31
Do you have magneto or distributor on your tractor the Mag doesn't need any outside power to work.
You should have about 8 volts output from the generator to charge the battery try adjusting the regulator.
Google adjusting regulators on the web
Walt
42FordGPW
02-02-2008 06:53:25
 Re: 6volt charging system in reply to Walt Davies, 01-30-2008 17:40:16
I"ll be the first to admit I don"t know anything about tractors...but it sounds like you need to polarize your voltage regulator.
