VAC Pullers
Jim W.
01-29-2008 16:41:43
We have pulled VA series tractors in the past with a great deal of success, but it has been 20 yrs. ago. I have been reading old posts all day and have a good idea of what we need to be doing. We want to be competitive, so I have some questions for you that are actively pulling. We will probably build two tractors for comparisons. We swapped pinions and bull gears on a VAI once to slow the tractor down. Wish I knew where those gears were today.
1. Where can I get an old 300 engine/head? 2. We have 28" and 34" rear wheels can we pull with the 34's if we use the 148cid engine?
3. Do I want 66 or the 67 tooth bull gears for pulling?
Anyone with any other helpful information please feel free to email me direct.
Eldo case
01-30-2008 12:24:30
 Re: VAC Pullers in reply to Jim W., 01-29-2008 16:41:43
148cid engine, a cam out of a 159cid a LP head for a 148 mill it all you can then you have to shorten push rods a 1/4" so you have valve adjustment. You will then have 210lb of compression. It will need the clutch beefed up. Run what ever tire you want.
Oliver Puller
01-29-2008 18:55:12
I do not pull a vac but I have a case 210B that I bought in non running condition and many of the engine parts were missing so I bought a vac engine to put in it. I used the tractor for a long time like this but the vac motor was worn out and used oil. I used my original 210b block and rebuilt it using a piston and sleeve kit for a 400b which is 148 cu in. I used the 210b head which for some reason has a 1/4" shallower combustion chamber than a vac and I used the vac cam and manifolds. This engine when first rebuilt had 210 psi compression. You have to run premium gas in it or it pings like crazy and will not shut off when it is hot. The bottom line is this engine has grunt like you would not believe. I now have a backhoe on this tractor and it weighs right at 10,000 lbs.
I think if you had this motor in a vac it would be a serious puller. So what you need is a 148 motor. They have more stroke than a vac motor and you need a 210b head to get the high compression. Just to let you know, the engine in my 210b is about 1/4" longer than a vac but it will still bolt up.
