DC hyd. pump
Butch NW WI.
01-29-2008 13:56:55
Fixing the hyd. pump in preperation to painting. Find I need spring08414AB and gasket 08420AB, I need new numbers to cross ref. these. CIH link does not work for me.
Thanks for help
Butch
L.Lamp
01-29-2008 16:53:09
 Re: DC hyd. pump in reply to Butch NW WI., 01-29-2008 13:56:55
Do you have the dual valve pump or the single? I broke both swivals and the pump head last fall plowing and could not get new head gaskets or the outer right head spring from CaseIH. They said dual valve parts were still available. I put the head back on with silicone rubber for the gasket and it is holding ok. The spring I took out of a parts pump.
Butch NW Wi.
01-29-2008 17:12:50
 Re: DC hyd. pump in reply to L.Lamp, 01-29-2008 16:53:09
Yepper its the age thing, it's a dual pump. I also have a spare single out in the barn but the spring might be different as it' from an older SC.
Butch
L.Lamp
01-30-2008 14:26:40
 Re: DC hyd. pump in reply to Butch NW Wi., 01-29-2008 17:12:50
I have both kinds and the springs are different. You should be able to get them at CIH. The pump I broke was a single.
