For DKase--DC HLP's
L.LAMP
01-28-2008 10:06:50
Since you answered the question below, were there any High Altitude Pistons made in 4" bore and of aluminum? Were the cast iron HLP,s flat toped or domed? Is there any data anywhere that tells what the increase in HP for these upgrades were? Thanks!
johndeereman
01-28-2008 13:02:58
 Re: For DKase--DC HLP's in reply to L.LAMP, 01-28-2008 10:06:50
i have the 3 7/8 bore with flat top pistons and 5576a head i have more than 27 hp so i dissagree with you on that dkase set up for all fuel except the gas tank i pull with a guy that has the 4 inch high compression with the 5505a head we have the same style tires he has 14.9 and i have 13.6 i out pull him most of the timeu can tell i got lots more horse than him everyone comments on that not tryin to start trouble just addin my 2 cents
DKase
01-28-2008 18:36:23
 Re: For DKase--DC HLP's in reply to johndeereman, 01-28-2008 13:02:58
If you had the 4570 head, and slowed the engine down to C RPM's you would have 27 HP. I do not recall saying that your DC had 27 HP. I was not writing about the D engine, rather the piston and head combinations available that include the C engine. DK
DKase
01-28-2008 10:52:02
The 3 7/8 Hi comp pistons were flat top. That is why they can not be used with the 5505, and LP heads. All the 4" that I have seen were the flat top flush with the deck pistons. I have seen both the flat top flush with the deck 4 1/16" and the 4 1/16" domed pistons that the dome fits into the 5505 and possibly the LP head. I have every head, and every piston in running tractors, but far from every combination. About all you have to do is grab the starting crank and you get a good idea what piston is in there. HP will range from 27 to well over 50. Exactly how much each combination would pushit up I have no idea. Hope this helps DK
