Gearing difference between D and DC tractors
Mathias NY
01-26-2008 14:31:16
Does anyone know how these tractors were geared differently? They have the same ground speeds, but different diameter rear wheels. Was it different final drive gears or different gears in the transmission? Thanks for the help.
Mathias NY
01-27-2008 06:43:51
 Re: Gearing difference between D and DC tractors in reply to Mathias NY, 01-26-2008 14:31:16
Thanks for the feedback. Those are the answers I was looking for.
DCDENNIS
01-26-2008 18:06:45
I have DO gears in my DC puller, dc=37 teeth, do 31 teeth,this brought speed up,I have a picture but do not know how to put it on hear, DCdennis wausau wi.
DCDENNIS
01-26-2008 18:01:32
I installed DO gears and axles into my DC puller, I beleve the DC had 37 teeth The DO had 31 this brought my speed up in all gears, got weight below 4500 lbs,I have a picture with both gears in the housing but do not know how to put it on hear, DCdennis wausau wi
johndeereman
01-26-2008 17:43:28
dc tom recomends puttin di sprockets in for pullin so id assume its all in the sprockets
Gene Dotson
01-26-2008 17:19:18
Different size final drive chain sprockets... Gene
Tom Railsback
01-26-2008 17:16:21
Mathias:
I suggest that you look at a parts book; you will see no difference in gears between the D and DC. I really can't account for the same speeds as shown in the operator's manual.
dctom42
01-27-2008 06:19:31
 Re: Gearing difference between D and DC tractors in reply to Tom Railsback, 01-26-2008 17:16:21
tommy, notice in the parts book there were different ring and pinion and other gears, to change speed, easiest way is to change sprockets finding the other gears would be very hard i am sure tg
