Well since I have been having problem find
old
01-25-2008 12:57:19
a clutch pressure plate for this SC how uncommon is it for one to have live PTO. Seems that I can find pressure plates for the one with out live PTO but no such luck so far finding one with live PTO
Don L.
01-27-2008 16:48:32
 Re: Well since I have been having problem find in reply to old, 01-25-2008 12:57:19
I have those parts in a tractor yet. A hand clutch and live power SC parts tractor.
Don L.
BasketCASE
01-25-2008 17:28:28
Maybe try a dealer who works with Hy-Capacity out of Humboldt, IA. They do a lot of power train type of parts, and I know they have DC clutches. I've never checked if they have SC parts.
LongCase
01-25-2008 14:23:25
 CASE clutch in reply to old, 01-25-2008 12:57:19
You might try Lakeside Faem Equipment ar Harrisville WI. 800 365 4863 They have a lot of older CASE stuff.
old
01-25-2008 14:29:38
 Re: CASE clutch in reply to LongCase, 01-25-2008 14:23:25
Thanks, I'll try them either tomorrow or Monday
Glenn F.
01-25-2008 13:45:45
I don't have production data in front of me, but they made the SC from '39-'54, and the last two years were the only ones with live power, so I'm sure they will be hard to find. I'm sure most people would think twice about scrapping a LPTO model out too. You may be hunting for a while. No match-ups at NAPA or clutch rebuilding shops?
Glenn
old
01-25-2008 14:19:34
 Re: Well since I have been having problem find in reply to Glenn F., 01-25-2008 13:45:45
Well I tried O'reilly's and no luck there. I'd try a clutch rebuild shop but the one I have has some broken castings and figure it can't be fixed. I'll keep tring for a while and then if I can't find one I might try to fix what I have by doing some welding but sure hope I don't have to go that way
Kevin Meier
01-26-2008 13:42:53
 Re: Well since I have been having problem find in reply to old, 01-25-2008 14:19:34
I can look on monday to see if we have one on hand. For a va?
old
01-26-2008 14:34:36
 Re: Well since I have been having problem find in reply to Kevin Meier, 01-26-2008 13:42:53
I don't know if they would be the same
Kevin Meier
01-26-2008 14:55:15
 Re: Well since I have been having problem find in reply to old, 01-26-2008 14:34:36
copy and paste this address and see if it helps ya
http://www.agpartsltd.com/MODELPART.asp?MODEL=113&CAT=1630&PCL=10
Kevin Meier
01-26-2008 14:55:05
mole
01-25-2008 18:23:55
most clutch shops can match up the old one to something that is close that can be made to work. I would take it to them any way and see what they can come up with.
old
01-25-2008 20:29:37
 Re: Well since I have been having problem find in reply to mole, 01-25-2008 18:23:55
I would but is a 100 mile gamble and thats just one way plus they can not give me any idea of the cost over the phone so I could well be out $100-300 and still not have any thing that will work
BarryfromIA
01-25-2008 16:38:32
You could try Don L at 507-433-0073. Some times he is on here, he has some used parts.
old
01-25-2008 17:45:38
 Re: Well since I have been having problem find in reply to BarryfromIA, 01-25-2008 16:38:32
Thanks
