checking starter and mag for SC
peter379
01-24-2008 15:54:23
I have a starter for a case SC and also a magneto. I would like to sell them on ebay but would like to check them out first to see if they are good as they came off a parts tractor that's been sitting for probably ten years. Could I take some wire and put gator clips on and hook to a battery. On the starter would I ground to the housing and put pos on the big nut? Should the drive jump out and turn. There is no solenoid on the starter. I have never messed with a magneto before and have no clue how to test it for spark. Thanks, Brad
C. Amick
01-24-2008 17:36:03
 Re: checking starter and mag for SC in reply to peter379, 01-24-2008 15:54:23
You may want to file the points on the mag with a piece of very fine sand paper or emery board before you test it. The starter should turn by putting power to it.
meL
01-24-2008 17:05:06
If you put voltage to the mag through the terminal on the cap where the groundout wire is attached, a screw with a nut, you will destroy the mag. 12 volts through the contacts and spring directly to ground will make a real mess.
Dutchman
01-24-2008 16:42:39
Brad, I check a MAG. by putting it in a vise [ just tight enough to hold it ] put a spark plug wire in a plug wire hole [ make sure it's ALL the way in ] and take a wrench and turn it... you may have to let it CLICK 4 times... While you are turning it put the other end close to the mag. [ or if you want just hang on to it ] LOL I turn mine over a few times to check the color of the spark... After you get spark from one plug hole move it to another till you have check them ALL.. ThAT'S the way I did mine... right or wrong... Mark
