Year and model
J.L. Bender
01-23-2008 17:36:49
I bought an older Case tractor and I can't determine what year or model it is. Previous owner said he thought it a 78 model...It has a 4 cyl David Brown Diesel Engine, maybe about 60 HP. it has square fenders. a 2X3 transmission..2 spd PTO..number on top info plate by steering wheel gives number 942979. Any help would be greatly appreciated..jb
Thad
01-24-2008 07:07:08
 Re: Year and model in reply to J.L. Bender, 01-23-2008 17:36:49
The serial # and the model of the tractor are stamped in the frame casting. This # is stamped on the right side up at the front corner of the engine area on a flat spot on the frame. This # will help us determine what you need to know. Thad
J. L. Bender
01-24-2008 12:11:00
 Re: Year and model in reply to Thad, 01-24-2008 07:07:08
Thad, the number was where you said that it would be.. it shows....1210 /1/11155743... what year and HP do you suppose it to be??thanks for your help,,jb
Thad
01-24-2008 14:46:24
 Re: Year and model in reply to J. L. Bender, 01-24-2008 12:11:00
You have a 1977 1210 should be around 65hp. Thad
Jerry Bender
01-24-2008 19:04:12
 Re: Year and model in reply to Thad, 01-24-2008 14:46:24
Thad, I thank you so much. I appreciate your time and information on my tractor. Now I feel if I need parts at least I will know what to look for..TY ... jb
J. L. Bender
01-24-2008 08:02:27
Thanks so much--I found this number stamped on the left side of engine yesterday (948211) butI will go back and check the right side. I appreciate your help..jb
johndeereman
01-23-2008 17:50:01
could be a 1210 or 1410 david brown spent alot of time on those old gals that number i cant help you with
J. L. Bender
01-24-2008 08:05:35
 Re: Year and model in reply to johndeereman, 01-23-2008 17:50:01
Thanks so much for you time and help. I will research those two models..jb
