900 case
jh
01-22-2008 18:04:13
I have a 900 Case with a 377 Engine what is the differnce between that engine than the one 930 a 401 i know the cubes is bigger is the bore just bigger or what also iam having a hard time finding any rebuild parts for my 377
caseman-d
01-23-2008 20:21:06
 Re: 900 case in reply to LarryNeohiocase, 01-22-2008 18:04:13
Gene,
Didn't think the 930 sleeves would work in the 900 377 with out boring the block, does block casting number make a difference or was I misinformed. Does this also apply to the late 500's and the 600???
caseman-d
Gene Dotson
01-23-2008 04:44:08
 Re: 900 case in reply to jh, 01-22-2008 18:04:13
These engines all used a 5 inch stroke. Originally had a 4.00 inch bore for 377 cu. in. and 4 1/8 inch bore for 401 Cu.in. A bore of 4 1/4 inch will yield 425 Cu.in.
Possible to get 451 cu. in. with stock parts, but takes a little machine work... Gene
LenND
01-22-2008 19:05:07
I think most places that sell overhaul kits don't have the 900--377 kit. Thay will sell you a kit for the early 930. The sleeves fit the block but are reamed out bigger for 930 piston.
jh
01-22-2008 21:30:34
 Re: 900 case in reply to LenND, 01-22-2008 19:05:07
So u saying just get a early 930 kit an the sleeves will fit in my block with out boring it an the pistons will work have u done this before
LenND
01-23-2008 13:54:50
 Re: 900 case in reply to jh, 01-22-2008 21:30:34
As far as I can find out you don't do any machine work. The outside of the sleeve is the same size in a 377 and the early? 401. The inside of the sleeve is made an 1/8 of an inch larger and bigger pistons put in. I am using one that was did that way. The overhaul kit comes already to put in, sleeves and the works. IH dealer should have them.
