Case SC split
old
01-22-2008 16:56:55
The manual calls for using pin part #139AA to do the split. So heres the question.
Can 3/4 inch treaded rod or 3/4 inch slick rod/round rod be used to do the same as that case part. Also the book doesn't show them well so can any body post a good picture of them so I can maybe make a pair of them??
Thanks
bradley martin
01-23-2008 06:03:54
 Re: Case SC split in reply to old, 01-22-2008 16:56:55
I have always used a 6-12" piece of rod to align the bell housing and engine. If you use bolts be sure to grind the threads off or they might bind. Good luck.
Ry
01-23-2008 04:52:50
Old- The pins do look like they would help - but I have split a SC and a DC tractor without them and had no real problems. I blocked up the transmision and pulled the engine ahead with a cherry picker.
Cummins 1955
01-23-2008 03:38:14
3/4" X 6" bolt with head cut off and well rounded is what we used. We have a complete set from 1/4 to 7/8. It makes repairs much easier when you line up bolt holes before sliding an assembly together.
