Case900
jh
01-21-2008 19:56:06
I have a Case 1958 late model i have the heads casting number 8110 was wondering if they are good heads also i have the psb rotart pump any one know how to tune that thing up
caseman-d
01-23-2008 20:10:57
 Re: Case900 in reply to comfortking, 01-21-2008 19:56:06
Americam Bosch were rotary style the german was in-line. The 900B got the inline at serial number 8141036 according to parts manual.
caseman-d
LenND
01-24-2008 13:53:33
 Re: Case900 in reply to caseman-d, 01-23-2008 20:10:57
I think that sounds about right. Do you have an idea when they quit using that type? My cousin has a 930 Comfort King and it has the American Bosch rotary on that. Identical to my 1958 900B.
LenND
01-23-2008 13:59:12
 Re: Case900 in reply to jh, 01-21-2008 19:56:06
The 1958 came with a round distributor type pump and the 1959 + early 930 came with the inline injector pump. But I imagine they could be changed for one to the other.
hunter1
01-23-2008 10:07:50
If you have a late b model - it would not have an american bosch pump. (unless the german bosch was swapped out)
jh
01-23-2008 14:21:54
 Re: Case900 in reply to hunter1, 01-23-2008 10:07:50
Whats the Differnce between the american bosh pump an the german pump how do u tell the differece
caseman-d
01-22-2008 20:13:39
 Re: Case900 in reply to combinekid, 01-21-2008 19:56:06
How can you increase the rpms then. My experience is the 4 cylinders have plenty of power but the 6 cylinders lack the rpm's.
caseman-d
LenND
01-22-2008 19:09:23
When you loosen the yellow bolts don't slide it very far or you'll have to much fuel and loose power. I wonder how I would know that? LOL
Jim From Calif
01-22-2008 16:30:58
This is how you turn-up a Case Injector pump on a Case 800 PSB American BOSCH.
1.. Take the cover off (4 bolt cover) you will find yellow paint on (2) bolts. Loosen these bolts & move racket forward to get more fuel & back to pump less fuel.
2.. Yellow bolts can be taken out of hole & move moved forward to next hole to increase fuel more..
NOTE: If you put a whole lot more fuel in, you may want to change tips on the injectors. To bigger holes so it doesn�t load the head on the injector pump.
I assume a 6 port Injestion pump on the 900 is the same..
jh
01-22-2008 18:37:42
 Re: Case900 in reply to Jim From Calif, 01-22-2008 16:30:58
Thanks jim Dos that increse more rpms or just fuel
Jim From Calif
01-22-2008 20:00:53
 Re: Case900 in reply to jh, 01-22-2008 18:37:42
This process just increases "Fuel" to the injectors, The RPM's are not changed.
jh
01-22-2008 21:35:14
 Re: Case900 in reply to Jim From Calif, 01-22-2008 20:00:53
Thanks Jim i took that cover off i didnt see any yellow paint but i found simlar to what u was talking about 2 screws @ the top with a slide adjustment mine was in the back 2 holes an slide all the way forward but the front 2 holes arent tapped out for the bolts to screw down into
