4cyl Wisconsin to a VAC?
Soldier Tom
01-21-2008 04:58:39
I came across a "Gimme" 4 cylinder Wisconsin engine on an old case combine pushed off in the woods. It is stuck now, but my nephew and I like to tinker. I was wondering how much trouble it would be to mate it up to the transmission of a 51 VAC I have. (It's engine is totally shot; part of a "take em both or nothing" deal). I just thought that would be an interesting project to see if a body could get em together to make a "gee whiz"? I've seen JDs mated to Briggs/Stratton engines and thought, hmmmm, I wonder. I welcome your thoughts and ideas...
Thanks in advance Walk in peace
toomanycases
01-21-2008 08:53:12
 Re: 4cyl Wisconsin to a VAC? in reply to Soldier Tom, 01-21-2008 04:58:39
Awe come on Dkase, all you had to do is hook it up to your tractor with the belt and then they would start, (sometimes). Remember too many times on the old NCM baler, we would try to start after refueling & have to hook the SC to the belt pulley to start them. Got old real fast. Never did solve the problem & that was in 1943. Dad finally sold the baler. Chuck
DKase
01-21-2008 05:45:44
Those 4 cyl Wisconsin engines are junk! Head gaskets blow all the time. Burn at least 3 times the gas that the VA engine would with less HP. Will not start warm. Run faster than the VA engine with NO low RPM torque. Have to run fast to cool. Will cost more to fix up than the VA engine. Fix your VA engine! Parts are all available at reasonable prices. If your block or head is bad thay can be found quite reasonably priced. You will never regret fixing it right. Nice little handy yard tractor. I have a 7' belly mower on mine as well as several eagle hitch attachments. Does yours have the eagle hitch? DK
