VAC Experimental Engine
Eric Hosette
01-18-2008 18:33:17
I posted awhile back about the VAC experimental engine that I have aquired. I have been told the reason the engines did not work out is because of their inability to idle without overheating. Is there anyone that can shed some light on why they didn"t pan out and what I should be careful of while running it? Thanks for the help.
Don Rudolph
01-19-2008 12:18:57
 Re: VAC Experimental Engine in reply to Eric Hosette, 01-18-2008 18:33:17
If you are referring to the Case aircooled combine engines, the problem seemed to be that the air cooling fins would fill up with dirt and chaff and then not cool properly, scoring the cylinders and other nasty things(usually #2 and #3).
