Hi Mel!!!!! , I have seen you giving great info all over these pages. Can I get you address to try to learn some from you. I am about to split the tractor and pull the Torque converter then the clutch pack, Everything I can change I am gonna. I was lookinh at Dale over at dale@[email protected]. he has been pretty patient id; ing my tractor. Is proir s/n 8314666 (converter dump inneutral circuit) The more I drain and replace, the better is gets, but still can't get some dirt in the bucket, or drag with float on. 2nd,3rd, 74th are really no go unless on flat road and just getting warmed up. I hope to take all of the problem areas out of the equation. Then go grom there, already check and cleaned and replaced the shuttle flow spool andthe clutch spool, a little better.. Again, still not enough progress for me to leave it alone and start workinh. Would you recommend taking the torque tube to the dealer to get them to re-build the converter, or do you think it is simple enough with a reasonable amount of experience and tools could do the job? I have turned a lot of wrenches in my time, just not on the innerds of a 580ck 1968. Thanks for your time Duby
