Case 1070 3 point
Bugs
01-17-2008 20:22:58
Wanting to remove 3 point control valve (draft control valve)to service it. After removing the four bolts, securing valve to housing, is it possible to unscrew the spool to remove valve? From looking at valve diagram, it appears, the shaft which is pinned to the draft control linkage is threaded into spool.Has anyone ever done this? Are there any negative factors in doing this?
turbo
01-17-2008 20:42:27
 Re: Case 1070 3 point in reply to Bugs, 01-17-2008 20:22:58
Yes, unscrew it. Makes it easy.
Bugs
01-17-2008 20:47:46
 Re: Case 1070 3 point in reply to turbo, 01-17-2008 20:42:27
Thank you.
