vac carburator/belt pulley pump
young farmer
01-17-2008 09:59:44
I have a 1948 vac case tractor. I am looking for the power needle and idle needle settings for the carburator. The manual I have doesn't list this. Is it 3 turns on the power needle and 1 and a half for the idle needle. I just need the ball park to get me started. Someone before me had the power needle out 8 turns. Also I have the belt pulley hydraulic pump out and it is in bad shape. Does anyone know a good place to get all the parts for the pumpe including the rocker arms? Thanks for any help
amo
01-18-2008 18:22:35
 Re: vac carburator/belt pulley pump in reply to young farmer, 01-17-2008 09:59:44
try vintagetractors.com for used parts. good uck
Joe (Wa)
01-17-2008 17:31:11
You don't say whether your carb is Marvel-Schebler or Zenith.
Go to the link below, when it loads, click on page G2 S16 for MS carb adjustment. Further down the page is Zenith.
This is a late VA service manual, most of it applies to your '48. If you go back to the index page, service & repair for your pump is in the Hydraulic Group.
You can find complete pumps on ebay pretty often. Don Livington is a probable source for pumps & parts. I don't have his e:mail handy, if someone doesn't chime in with it, post back I'll hunt it up.
Joe
old carb
01-18-2008 19:15:32
 Re: vac carburator/belt pulley pump in reply to Joe (Wa), 01-17-2008 17:31:11
The carb has a make and a model#.OLD CARB
Bill_Utah
01-17-2008 15:20:34
Young Farmer
I would start with Case IH Parts, after that It is probably off to the salvage yards.
Bill
CENTAUR
01-17-2008 10:26:43
It does not matter as you have to adjust both IDLE and HIGH SPEED CIRCUIT anyway after you get it running. CENTAUR
