Char-Lyn steering
tomturkey
01-14-2008 12:28:51
I have a char-lyn steering assist unit on my "400 Case". The part that attaches to the steering sector leaks. I've tried the ez power steering stop leaks, now it time to replace seals or o-rings. Can anyone give advice b-4 I dive into the unknown??? Thanks...gobble
Genos
01-19-2008 18:24:05
 Re: Char-Lyn steering in reply to tomturkey, 01-14-2008 12:28:51
Make Sure You Get The Proper O Rings, some Are Flat, Maybe all Off Them. I Had One I could Not get To Stop Leaking After Many replacement round O-rings. Told An Agco Dealer About It & He ordered Proper Seal Kit & It Fixed It. Don't Know If Case/IH Can Get Kit? this was A Friend That I Told About It & He Had The Answer.
tomturkey
01-16-2008 06:19:03
Thank you Joe and Walt for your response. I do pretty well with pictures. gobble
Joe (Wa)
01-15-2008 09:44:12
Go to the link. Torque generators are down near the bottom of the page. You probably have the early 217 series 3.5 gpm unit.
Click on the word "English" for a pdf file with exploded parts view and general info.
Joe
Walt Davies
01-15-2008 09:17:06
They are fairly simple things just lay it out on a very clean surface so that you can see what goes where when you reassemble it. Clean all parts look for wear and replace all "O" rings and seals. Don't skimp on parts you only want to do this once.
Walt
