SC hand clutch parts part 2
old
01-12-2008 13:08:12
Well I got the SC today and as I was told the clutch isn't as it should be. If you lock it in its hard to get it to release. Now my problem is this. I have an I-T manual that covers the SC but I don't seem to be able to find where it talks about the hand clutch but it does talk about a foot clutch. Can any body help me out here as to how to work on this tractor and replace the bad parts. Also can I see what is wrong by removing the side cover plate?? Thanks
bradley martin
01-12-2008 14:34:56
 Re: SC hand clutch parts part 2 in reply to old, 01-12-2008 13:08:12
Old, you will likely be able to see what is wrong by removing the side plate. There will be 3 linkages on the over=center mechanism. It is possible that the pin in 1 of these has fallen out. It is also possible that it is out of adjustment. Either of those problems can be corrected w/o splitting. Good luck.
