Case-O-Matic
hobbyfarmerinwi
01-12-2008 09:13:06
As I have stated before I am looking at an 830.
Is it a COM.
My question is, what in the world is a Case-O-Matic?
Do I want to have one, or run away from it.
The tractor will be used for moving/lifting large bales
I have a 311 for all the other small chores around the place.
NE IA
01-13-2008 18:54:50
 Re: Case-O-Matic in reply to hobbyfarmerinwi, 01-12-2008 09:13:06
For the jobs you described it will be great.
My dad thought they were the greatest thing since indoor plumbing.
The biggest problem is if you put it on a pto baler, chopper etc with the tractor in motion it works great. However if you must stop the ground motion and inch forward with the tractor running pto speed you are in big trouble. Because it would be no different than running your automatic transmision car at 3/4 throttle and dropping it from park or nuteral into drive. You must always without exception slow the engine down to a idle before letting the clutch out. It realy has no clutch it is rather a valve that is either in or out. You can try to attempt to stop the forward motion of the tractor at pto speed by braking, but it again is like a automatic auto transmission and power breaking it.
Dad had a 730D that was the best treactor a man could ask for. He had it probably 20 plus years and fuel and tires, and batteries were his only expence.
I will get crap on this, but his 3020D JD with a power shift could out do the 730 in the house yard, but once you get to the field and dropped the plow in the ground the 730 wore the pants. Not as handy as the 3020 for comfort and ease of operation maybe, but alot less black smoke and a lot less fuel when doing tillage work.
J heitkemper
01-14-2008 10:46:38
 Re: Case-O-Matic in reply to NE IA, 01-13-2008 18:54:50
Have to agree with you on all counts of Comparison with 3020 and 730 ,,Case tractors are awkward devils compared to those JD built after 1960 , Not true back in the 50s... the DC rules ! . OK guys,,,,, ,, ,, Hands Down I would rather pay the fuel bill for any CASE tractor over a DEERE , Especially My 800
Harry J. Case
01-12-2008 19:21:26
Hey Hobbyfarmer I think you will love that 830 with C.O.M. the torque convertor will start incredible loads with no wheel spin, you start the motion of the tractor in c.o.m.(on the torque converter)an
d shift into direct drive once you are up to speed, you can also shift back to the torque converter(case-o-matic) if you come to a wet or tough spot while plowing or whatever. Have fun,Harry Case,Allis,Moline nut
hobbyfarmerinwi
01-12-2008 17:26:23
Thanks for the background.
I will be taking the tractor for a drive next week.
How do I tell if the COM is good or weak? What am I looking for?
Jim From Calif
01-12-2008 10:13:42
A 830 COM is a tractor with a �lockable� Torque Converter instead of a clutch. If you learn how to operate the COM, you will love it. However, they are not cheap to rebuild if the COM unit is weak, slipping or not �locking�. My 800 COM has been operating great for 50 years now with only routine yearly maintenance.
J heitkemper
01-12-2008 10:27:56
 Re: Case-O-Matic in reply to Jim From Calif, 01-12-2008 10:13:42
And It LOOKS GREAT too!..Nice Job Jim !,,. Have an 800 here that I enjoy , Great tractor , Although You will learn by doing with this tractor ..Great Novelty ,Need to do a seal job on the Pump ,, Hope to get done this winter , if not Should be OK for asnother season of hay bine work,, No plowing for now ,, Best wishes Jim
