830
hobbyfarmerinwi
01-10-2008 18:36:43
I am looking at a 830. It has a loader on it. The guy selling it is warning me that due to the fact there is no real frame to the tractor, whenever they lift a heavy load with loader the gasket between engine and trans leaks due to flexing.
Does anyone know anything about this?
He also thinks it is about a 60hp tractor. Is that close?
Thanks
hobbyfarmerinwi
01-11-2008 16:55:22
 Re: 830 in reply to hobbyfarmerinwi, 01-10-2008 18:36:43
Thanks for all your help. I am not sure about the COM, as this has started as a casual conversation. I am in a good position as a buyer due to the fact the seller is going out of his way to tell me what all is wrong with the tractor, rather than just trying to sell me on the good parts.
With the feedback you have all offered, I will now spend some extra time looking it over.
Again, thank you all
M Nut
01-11-2008 10:15:56
I've had a loader on a 830 Case for 30 years. It is an Allied loader that attaches on the front of the tractor just below the radiator and then extend to the back axle. I've moved 1000,s and 1000,s of large round bales and never had to replace any seals at all. It has been a great loader tractor. That's all I use it for because she sure likes her gas!
comfortkingcd14c323902024
01-11-2008 04:43:33
Is this tractor a case-o-matic? If it is it could be leaking at the joint between engine and converter, otherwise it is leaking between converter housing and the trans case. I have seen tractors seep oil between the converter housing and the trans when the gaskets get old they shrink and there could be some seepage of oil. On the non COM tractor you can try ti tighten the two bottom nuts. The loader frame would have more play in the mounting pins than would the mating surfaces on the tractor. Best to have him show you while it still his tractor. Any one of the leaks could require splitting the tractor. leaking at
LarrySTN
01-10-2008 21:25:13
The Case 830 is supposed to have a dry clutch housing. It shouldn't leak even if it did flex a little.
INCase
01-11-2008 04:48:13
 Re: 830 in reply to LarrySTN, 01-10-2008 21:25:13
If it was a Case-o-matic it will have fluid in the torque tube and could leak. May need to be retorqued or something else could be wrong. Also what is the owner referring to as "heavy loads"??? Could have been abused.
Nedd
01-10-2008 19:56:23
Case iron breaks before it would bend that much. I would bet the tractor has been split for a "quicky" repair and they used the old gasket. Had a loader on the 830 for over 15 years with no problems except the power steering squeal.
Jarrod Shimp
01-10-2008 19:23:52
Well the 830 is about 65hp. I am actually looking for a decent 830..... however the problem that you spoke about seems a little odd. All the 830's I've seen with loaders have the type of loaders that have a frame running to the back axle.....so if this loader doesn't have that type of frame....it might cause the tractor to flex. Still....I have never heard of a tractor flexing so much that it opens up a seal in the mid section. If your interested in it as a loader tractor....I would look at how the loaders frame is...it needs to be the full frame type that runs from the front of the tractor to the rear axle.
hobbyfarmerinwi
01-10-2008 19:35:09
 Re: 830 in reply to Jarrod Shimp, 01-10-2008 19:23:52
The loader is bolted to the front on each side, and to the back behind the fenders.
Thanks
