SC hand clutch parts
old
01-10-2008 15:17:45
I have a chance to buy an SC with hand clutch and the guy says it has a clutch problem and something about one of the 3 fingers are broke off the pressure plate. How hard it that to fix and about what will it cost?? Plus where do you find the parts to fix the problem. I'm not much of a case man so if I do buy it I will probably have more question. Also about what is one worth it has good tires and runs ok but has this clutch problem. Also has an eagle hitch on it and live PTO.
Thanks
Dave 2N
01-11-2008 06:17:46
 Re: SC hand clutch parts in reply to old, 01-10-2008 15:17:45
old-
Goodrich Auction Service, Newark Valley, NY. He has a several acre boneyard of Cases. I think he has a website. I don't have a Case, would like to get one and am probably downright dumb for not having one because of the proximity of this boneyard and the number of tractors in it.
watsosngotit
01-10-2008 16:30:04
If one of the fingers on the pressure plate has been broken, I would split the tractor, Pull the clutch and pressure plate and inspect all of it. Repair as needed. You may want to go to your local clutch rebuilder. I would think you could buy a reconditioned pressure plate, clutch, and throw out bearing for $300 or less. The biggest part will be the spliting of the tractor. Eagle hitch and live pto help the value of the tractor.
steve il
01-10-2008 16:10:01
 Re: SC hand clutch parts in reply to kirk in ks,, 01-10-2008 15:17:45
old said: (quoted from post at 00:17:45 01/11/08) I have a chance to buy an SC with hand clutch and the guy says it has a clutch problem and something about one of the 3 fingers are broke off the pressure plate. How hard it that to fix and about what will it cost?? Plus where do you find the parts to fix the problem. I'm not much of a case man so if I do buy it I will probably have more question. Also about what is one worth it has good tires and runs ok but has this clutch problem. Also has an eagle hitch on it and live PTO.
Thanks
Hobby farm
Hi, ihave an sc parts tractor already split ,i think i know the part you need. are there any problems with selling parts on this disscussion site. great site i dont want to cause a problem. steve
old
01-10-2008 16:57:39
 Re: SC hand clutch parts in reply to steve il, 01-10-2008 16:10:01
No problem with selling parts as long as you use the ADs area on the side or if you offer them like you are here. I don't know for sure if I'm going to be buying it yet but will post back if and when I do because I'm sure I'll need parts
Dutchman
01-10-2008 15:51:47
Old, SC tractors are lots of them... as for parts... look on e-bay... theres always sc parts there.. thats were I find mine.. As for price ... check on e-bay also... the sheet metal and how good the tires are tells a lot... SORRY ... I couldn't answer you better,.. I'm sure someone else will jump in hear and help out... Mark
