will it work 2870
4 R's
01-10-2008 12:08:11
Found a 2870 motor for the 4890. are they the same, hp? what would we need to modify or check?
Damp;Dservice
01-11-2008 19:19:48
 Re: will it work 2870 in reply to todd hamilton, 01-10-2008 12:08:11
The sooner you get rid of that pos 4890 engine the better off you will be! I think the 2870 engine may be a little lower on power but not 100% sure. I am doing an inframe on a 2870 right now, bottom end is done, just waiting to find a good set of head cores to have rebuilt, the origional heads were cracked to death.
jogl
01-11-2008 02:59:28
 Re: will it work 2870 in reply to 4 R's, 01-10-2008 12:08:11
Just curious, what happened to the original engine?
JP.
Tom (Ks)
01-10-2008 16:43:09
Everything is the same as far as I know. On the early 2870's the decal on the pulley will come off and you will not know where the timing marks are. Dealers were supposed to scribe a line across the pulley to mark TDC and pump timing, but I don't think very many did that. Check that before you install the engine.
4 R's
01-11-2008 07:12:30
 Re: will it work 2870 in reply to Tom (Ks), 01-10-2008 16:43:09
I will definitely check for the timing. The engine that is in there now keeps leaking water out of the head gasket, gaskets been replaced multiple times, lasts a year then goes out.
tractorpuller
01-11-2008 08:14:10
 Re: will it work 2870 in reply to 4 R's, 01-11-2008 07:12:30
Did you make sure the head or block is not warped? Sounds like one or both may be. I would check that.
4 R's
01-11-2008 12:02:44
 Re: will it work 2870 in reply to tractorpuller, 01-11-2008 08:14:10
heads were resurfaced but not the block. That front piston just always leaked water after awhile. temp always ran 200+ and after replacing the head, over time she really started losing power.
