la/900 rear axle
docjoe
01-08-2008 19:40:12
Are the la rear axles and the 900 the same on the outer end? Does the la have a nut on the end? Thanks joe
docjoe
01-09-2008 16:40:35
 Re: la/900 rear axle in reply to docjoe, 01-08-2008 19:40:12
Thanks for the info I make some hubs for other tractors and was thinking about trying some of these. I have a 900 to work from but didn't know if they were the same. Thanks joe
Don Rudolph
01-08-2008 20:22:41
Joe,
I was told by several Case experts that when I got 34" hubs for my 500 that they had to come off of another 500 and not a 600 or 900 because the axle taper is slightly different. Supposedly LA and 500 axles are the same. Don
caseman-d
01-08-2008 20:05:32
 Re: la/900 rear axle in reply to Roger (Mi), 01-08-2008 19:40:12
Joe,
LA does have a nut on the end of the axle. Part number is O6000AB. Showing axle shaft for 900 being A11331 The outside nut is used on the LA, 500, 600, and 900. Same on the inside nut. Am showing different axle number .
caseman-d
