just bought a 49 Case LA I have a couple questions
olicat74
01-07-2008 20:11:36
First of all there is a lever attached to a rod to the left of the throttle that goes to the magneto. What is this for and how far shold it move.It wont move much. Also it has hydraulic brakes on it that do not work. What is the easiest way to tear into the brakes and get them working. Right now it does not run.
olicat74
01-08-2008 04:02:29
 Re: just bought a 49 Case LA I have a couple questions in reply to olicat74, 01-07-2008 20:11:36
OK I took the cover off yesterday and thought maybee that that brass ring with the slots should move. I'll make a tool and give it a try. As for the brakes I was afraid it would be a pain by looking at it. The tractor does roll so I guess thats at least one good thing. Thanks for the info
Gene Dotson
01-08-2008 02:51:07
Afraid you will not find an easy way to unstick the brakes without removing the hubs which weigh about 900 pounds each. Hopefully the wheels now turn? and shoes not stuck to the drums. New master cylinders are available from Wagner and the wheel cylinders will have to be rebuilt. I have wheel cylinder cups and dust cover if you are interested.
The governor advance rod sticking, do not force it with the linkage or the cap as you will bend the spring tang that turns the advance mechanism. remove the cover and make a tool that will fit in both slots with a handle for leverage.Use your favorite penetrating oil generously and be careful to not damage the brass ring... Gene
AllanC
01-07-2008 20:26:01
The lever you are wondering about is spark advance/retard. Pull back to advance, usually where it runs if timed right. Push foreward to start with the crank so it won't backfire. The brakes may be quite a job, Depends is they are all siezed with rust or just need the hydraulic part fixed up. A Manual is the first step.
Bob from Australia
01-07-2008 20:44:23
 Re: just bought a 49 Case LA I have a couple questions in reply to AllanC, 01-07-2008 20:26:01
The lever also shuts the engine off by grounding the magneto. Should not be hard to free it up so it works properly.
