DC3 to wide front end swap - pics
grapefarmer
01-06-2008 20:21:23
Here are some pictures of my progress installing the DC4 front on my DC3. One cool thing is you can install the front end while leaving the tractor supported on the tricycle front. My wishbone is about 2 inches short of the pan bracket. But my wishbone was broken and been welded on. I will have to cut it and re-weld it back to the correct hight. If anyone has a DC4 steering arm and steering rod for sale or a picture of one, it would sure help me.
Thanks
-Dave
third party imagethird party imagethird party imagethird party image
Old Iron Larry
01-07-2008 12:08:11
 Re: DC3 to wide front end swap - pics in reply to grapefarmer, 01-06-2008 20:21:23
Looks good. I am in the process of putting an adjustable widefront on my DC. Am still rebuilding the axle and king pins, but I will get done someday.
grapefarmer
01-07-2008 16:18:48
 Re: DC3 to wide front end swap - pics in reply to Old Iron Larry, 01-07-2008 12:08:11
I could not get new axle pins, so I had to machined them myself. Not much of a machinist, but they came out ok
J Heitkemper
01-07-2008 19:44:47
 Re: DC3 to wide front end swap - pics in reply to grapefarmer, 01-07-2008 16:18:48
Wide front DC 4 s use 1920 technolgy , Got one here that runs down the road in high gear like Jethro on the Beverly Hillbillies ,, Takes a 40 ft circle to turn arond,, Always wanted to find a A W F ront for My SC or Dc ,, I Would Think they would steer Quite Easily , Anyone Got One
david from mo
01-09-2008 15:44:40
 Re: DC3 to wide front end swap - pics in reply to J Heitkemper, 01-07-2008 19:44:47
I have a friend that has one he would sale. Think he has about 20 old cases that run . This in Mo e-mail me and I can give you a phone # david
grapefarmer
01-12-2008 08:12:17
 Re: DC3 to wide front end swap - pics in reply to david from mo, 01-09-2008 15:44:40
David,
I was able to find one just the other day. So I am ok for parts need.
Thanks
-Dave
Glenn FitzGerald
01-07-2008 09:55:02
I like the looks of the DC4 configuration. You will not like the way it steers unless you have biceps like Arnold Schwarzenegger. Not too long ago I switched my '53 DC from the front axel you are mounting to an adjustable wide front. It now steers very nicely.
Glenn
Tom Railsback
01-08-2008 14:14:43
 Re: DC3 to wide front end swap - pics in reply to Glenn FitzGerald, 01-07-2008 09:55:02
I have no trouble steering my 1940 DC4. In fact, at one time the steering gear was too loose and it wobbled all over the road.
It has turning brakes and I use them freely.
DKase
01-07-2008 10:35:01
You should be able to jack the wishbone up and put the pin in. DK
grapefarmer
01-07-2008 16:16:51
 Re: DC3 to wide front end swap - pics in reply to DKase, 01-07-2008 10:35:01
Thanks, I'll give it a try.
-Dave
