Does a bear poop in the woods?
Roger (Mi)
01-06-2008 08:59:09
Can a 970 or 1070 compete with IH 966 or JD 4230? Does a bear poop in the woods? A well prepared 970 or 1070 can leave them in the dust.
A 451 with a turbo will out perform a 504 without a turbo. It's not even close. If you develop 250 or more horsepower from the engine and use a powershift transmission, you'll need to make modifications. Shims will need to be added to the powershift pressure relief valve to increase pressure in the clutch packs to prevent slipage. Tension will need to be increased on the torque limited disc on the flywheel to also prevent slipage. As with any tractor, the better the preparation, the better the pulling.
