930 sucking air
DCP
01-05-2008 20:39:11
My 930 periodically dies of fuel starvation when all three fuel filters become filled with air. It's not because the tank is near empty or running on a hillside. Rather it seems there is an air leak between tank and the primary filter. I've replaced filter gaskets and bleed screw gaskets to no avail. I can't find any fuel leak in the line - it justs sucks air. Is the primer pump likely to be the problem? Has anyone else dealt with this problem?
Thanks for your advice.
DCP
DKase
01-07-2008 05:56:05
 Re: 930 sucking air in reply to DCP, 01-05-2008 20:39:11
Take the fuel line off at the priming pump. Fuel should gravity flow out at full flow of the line. If it does not there is a restriction in the line from the tank. DK
mEl
01-06-2008 10:57:11
i have seen the inlet valves in the primer pump body jammed full up debris starving the fuel system, remove the pump from the filter base and disassemble it and check for plugged valves, be sure to check both the inlet and outlet valves. they are in the body at the fitting where the inlet fitting goes in and also where the pump assy screws into the filter base.
Doc Larry
01-06-2008 06:47:52
Another possibility - if this has a fine mesh, non-replaceable primary filter, it might be clogged with accumulated varnish and gunk. You can clean most of it out with a mix of acetone and denatured alcohol. Dead moths, bees, and flies in the fuel tank can also clog things up!
STUDIEDIESEL63
01-06-2008 05:31:45
Hi,are you sure its an air problem?We have 2 930s and had this happen.Thought to it was "air"cause I was getting fuel through to the primary filter.But after 35+ yrs.the fuel tank valve assembly had gotten partially gunked-up with kinda smeary black stuff.Been probably 5yrs.for 1 and 2yrs. for the other since I cleaned them. Still will blow black smoke with the bestof them ! Good luck.
petetx
01-05-2008 21:42:49
had the same problem with my 1030 replaced the priming pump runs ok now that was 2 yr. sgo
DCP
01-06-2008 08:14:47
 Re: 930 sucking air in reply to petetx, 01-05-2008 21:42:49
Thanks. I"ll try your suggestion. I think I"ve ruled out the other possibilities since I"ve had the tank removed and cleaned and replaced the filament filters 2-3 times.
Cheers
