Looking for a used piston for David Brown 990
Joe Stewart
01-05-2008 15:18:19
Hello, I acquired a 990 tractor with a frozen motor. I poured diesel down the exhaust manifold and opened up all the valves and let it sit for a couple of weeks. Tried to yank it with a chain while popping the clutch => engine would not budge. I took the head off today and three of the cylinders are pristine! The fourth had water in it and the top of the piston was severely corroded to the point where the combustion chamber is bowl shaped. Still haven't got it free, but when I do, I will need a replacement piston. The other three pistons have "D78" or "D79" stamped on the top - hard to read - not sure if thats what it says or what it means. Does anyone have one (1) spare piston with used rings still attached and preferably the attached connecting rod? I'm looking for the bottom oil bowl for the air cleaner also. Any ideas on who I can call? Thanks for any help. Joe Stewart
Joe Stewart
01-05-2008 17:51:26
 Re: Looking for a used piston for David Brown 990 in reply to Joe Stewart, 01-05-2008 15:18:19
I guess I'll have to check the block to see if its solid or wet sleeved. I know that the data plate is still on the tractor but I forgot to copy down the S/N. Hopefully I will get this information tomorrow and repost. Thanks for the replies so far. Any idea what those stamped numbers on top of the pistons mean? Are there various bores or only standard? Joe Stewart
Don Livingston
01-05-2008 17:12:32
I have a used engine parts for a 990.
Ph 507 433 0073
rcjr
01-05-2008 16:33:56
Does your tractor have a wet sleave engine or
a solid block. The older 990 have wet sleave
and the newer have solid block.I have a used piston for the wet sleave because I just
rebuilt my 990 and put new pistons in.
