Case 580C starter
Don Novak
01-03-2008 14:23:47
Engine seems to crank slow. Wondering if the starter is draging? How many amps should the starter draw. Secondly, how do you measure the cranking rpm on a diesel engine.
mEl
01-03-2008 14:59:54
 Re: Case 580C starter in reply to Don Novak, 01-03-2008 14:23:47
Don, Check the battery and charging system complete including cables to insure that they are adequate, check your battery cable ground to the frame, make sure the battery is the hottest cranking amps that will fit the box. If you have a Delco starter don't waste your time or money on it. Go to a Case IH dealer that sells the Megavolt line of rebuilds, be careful the chinese knockoffs as they are not as good. You want the Nippondenso replacement starter for the 580 c-d a three bolt unit as contrasted to the two bolt used on the case-cummins engine. You will probably have to add an auxilary solenoid to help engage the new starter as the neutral start circuil is a bit light for the newer starter, A cab solenoid and harness kit from a 2290 ag tractor cab solenoid conversion is ideal I have used them by the dozens. The Gear reduction starter recommended is vastly superior.
