Hot coil
JGarner
12-31-2007 08:12:06
After idleing the old 630 yesterday just to run it some it was acting like the float was hanging and it was spitting,sputtering and back firing so I shut it down for a few minutes and turned the gas valve off. About 15 minutes later I started it and it idled smooothly for about 10 minutes. I noticed it starting to miss fire and act like it was going to die. Having just put a gallon or so of fuel in the tank I thought it was running low so I just shut it off nntil I could get it back in the garage.
I happened to be working on the distributor side of the engine and noticed that the coil was very hot, almost too hot to touch. Any ideas? I haven't ever noticed a coil getting that hot before on any other cars, trucks, tractors or the like. It was about 55 out yesterday so air temp is out.
JGarner
caseman-d
01-02-2008 20:36:51
 Re: Hot coil in reply to allenmichael, 12-31-2007 08:12:06
Are you sure it's a 12volt coil. Could be a 6/12 voilt coil and the resister is gone or maybe bad.
caseman-d
C. Amick
01-02-2008 09:19:21
 Re: Hot coil in reply to JGarner, 12-31-2007 08:12:06
Is the battery holding charge between usage?
Joe (Wa)
12-31-2007 14:07:31
I boiled the oil out of one that was mounted horizontally just by inadvertently leaving the ignition on for a couple hours. Too hot to touch.
Joe
Walt Davies
12-31-2007 09:56:45
Sounds like it may be shorted inside try another one they are easy to get at any Auto parts store.
Walt
JGarner
01-01-2008 14:13:39
 Re: Hot coil in reply to Walt Davies, 12-31-2007 09:56:45
Thanks Joe and Walt you confirmed my suspicions. Been thinking about converting to Petronix electronic ignition and replacing coil, wires, etc. This just gives me a good excuse.
JGarner
