Case skid steer hydraulic pump
HossW
12-30-2007 19:29:27
Does anyone know how to bond a steel fitting to an aluminum hydraulic pump. The threads are stripped out of the pump on the suction side, so I need some options. BTW this is on a Case 1530 B skidloader. Thanks.
Hoss
Cummins 1955
12-31-2007 18:34:08
 Re: Case skid steer hydraulic pump in reply to HossW, 12-30-2007 19:29:27
I have had luck on bolts using the form a thread from lock tite. I you coat the threads with a release agent and then two part epoxy it in place. Follow the directions exactly! I have not tried it with hydraulic fitting, but have repaired many bolt holes with it. Once, we were in a jam to get a machine running and needed an odd ball metric tap. With none available, we over sized the hole and used that stuff to get it running. It ran for several years until the machine was retired.
