TEMP GAUGE ON VAO
garys vao
12-30-2007 12:55:19
bought a new reproduction thermo gauge and it won't tighten up together where it screws into the reducer they send with it. well i had to go for a ride and see if it was just the way they are . wrong. it just barely seeps but has to be jury rigged or something. it started to go to the red about a 1/4 mi. down the road,then it returned to somewhat normal. so i turned around and came back. i topped it off with new anti and the temp gauge fell all the way to cold. i let it run for awhile but it never warmed the gauge. took the cap off (no pressure) and the liqiud was circulating. didn't feel hot. so what the hecks going on? thanx Gary
Mike Burton
12-31-2007 05:10:55
 Re: TEMP GAUGE ON VAO in reply to garys vao, 12-30-2007 12:55:19
I know that on my VAC the temp. guage never even registered till I put a thermostat in it. Now it runs at 160-165. As to the sending unit seepage, if you haven't done so, try some teflon thread tape.
mikefromiowa
12-31-2007 04:57:56
 Re: TEMP GAUGE ON VAO in reply to Joe (Wa), 12-30-2007 12:55:19
or no thermostat?
TimBinWV
12-30-2007 13:40:31
Stuck thermostat?
Paul f
12-31-2007 08:39:20
 Re: TEMP GAUGE ON VAO in reply to TimBinWV, 12-30-2007 13:40:31
If you have a thermostat it is normal (at least in both my DC and VAC for the temp to go 20 degrees or more above the thermostat rating before it opens then it runs at the specified temp. I think there are 2 possibilities..the sending unit is near the head and that area gets hot first (before teh water up near the thermostat (which in the VAC is sort of insulated up there in the radiator hose).
If it gets really hot there maybe some air trapped in the hose below the thermostat further insulating it. I would suggest drilling a small hole 3/32" +/- in the thermostat flange to let any air escape/circulate.
By the way the Va system is not pressurized
Joe (Wa)
12-31-2007 14:12:58
 Re: TEMP GAUGE ON VAO in reply to Paul f, 12-31-2007 08:39:20
Paul, my VAC did the same thing. Center clamp was too tight.
Joe
