Transmission brake parts 930 D
J. Klein Rot
12-30-2007 04:30:36
Hi,
I am restoring an Case 930 Diesel, and on the righthandside of the transmission is a cover missing. Someone said that this was for the transmission brake. I need this cover and the drum and the brake band. Were can i find these parts??
LenND
12-30-2007 14:24:59
 Re: Transmission brake parts 930 D in reply to J. Klein Rot, 12-30-2007 04:30:36
You can leave the brake off if you can't find one. And just put the plate on with a gasket or it will leak.
DKase
12-30-2007 10:11:26
The only trans. brake that I am aware of on a 930 is the small clutch brake on the 6 speed models. If yours is a 6 speed I have one in the trees that should have the trans shaft cover that you need. Need more info though. DK
J. Klein Rot
12-30-2007 10:37:32
 Re: Transmission brake parts 930 D in reply to DKase, 12-30-2007 10:11:26
OK DKase,
I will go to the tractor and see what the serial number is and what kind of transmission it has.
I forgot i need also a good startermotor. please reply through my Email.
