Case 580SD white smoke from the exhaust
Mike Gotto
12-28-2007 07:22:51
I had the fuel inhection pump from my backhoe rebuilt (leaky throttle shaft), I also had the rad rebuilt. when I put everything back together I went to start it and got white smoke from the exhaust. I only tried it a couple times(was getting late) This job was done over a months time, indoors.Doesn't white smoke mean coolant? There's fuel at the injectors, not enough to start but I need to make sure that the white smoke is n't from a head gasket or ? any thoughts out there??
Moe2
12-29-2007 08:54:36
 Re: Case 580SD white smoke from the exhaust in reply to Mike Gotto, 12-28-2007 07:22:51
If the coolant is leaking it will sometimes take on a greyish (murky) color. Check that.
Lodemia2
12-28-2007 07:31:05
Unburt diesel fuel. Get it started and it will probably be OK. Diesels will due this if they are not getting enough fuel to start. Just part of the system bleeding process. Make sure all the filters are bled off and you have enough fuel to the injection pump. May have to bleed the pump and the injector lines also.
Lodemia2
12-28-2007 07:30:40
Unburt diesel fuel. Get it started and it will poobably be OK. Diesels will due this if they are not getting enough fuel to start. Just part of the system bleeding process. Make sure all the filters are bled off and you have enough fuel to the injection pump. May have to bleed the pump and the injector lines also.
Mike Gotto
12-28-2007 07:31:43
 Re: Case 580SD white smoke from the exhaust in reply to Lodemia2, 12-28-2007 07:30:40
Thanks.
Doc Larry
12-29-2007 06:37:32
 Re: Case 580SD white smoke from the exhaust in reply to Mike Gotto, 12-28-2007 07:31:43
If the white smoke continues after you get it running and warmed up, yes, it"s probably coolant.
Larry
