case 301 head gasket kit.
jbf203
12-27-2007 09:46:35
Trying to determine what the remaining peices from the set are for. There are 6 copper washers, 4 rubber washers/o-rings, and one small seal,that I'm unsure what they go to. The motor is in a case 830 tractor...maybe these parts go with a differment application? Any help would be appreciated. Thanks.
Nedd
12-28-2007 06:14:36
 Re: case 301 head gasket kit. in reply to jbf203, 12-27-2007 09:46:35
What do the copper washers look like? There are copper rings that go on the tip of each injector for seating to the head. Small orings for the fuel lines returning from injectors. Just guessing....
djm75
12-28-2007 03:55:18
I had the same leftovers you did when I did my 830.
Triplerange
12-27-2007 10:20:58
Diesel Injection pump, maybe
