801B Diesel Case-O-Matic Shift Pattern
Harlan Young
12-26-2007 10:53:40
Would anyone have a picture of the shift pattern for a 800 Case O Matic? thanks!
Jim B
12-28-2007 08:51:48
 Re: 801B Diesel Case-O-Matic Shift Pattern in reply to Harlan Young, 12-26-2007 10:53:40
Can't supply a schematic but it's a simple: double 4-speed, H-Pattern. If your having problems finding a gear it's probably that your not finding/using the double neutral. When in either higher-gears neutral or lower-gears neutral the lever must be centered carefully and moved either straight up, or down to the opposite neutral, then into the H-pattern for gear selection. A little difficult to master but once you understand the feel it works quite well. Hope that helps.
caseman-d
12-27-2007 20:27:22
 Re: 801B Diesel Case-O-Matic Shift Pattern in reply to Terry Cuddeford, 12-26-2007 10:53:40
There was a shift pattern plate listed on ebay about a week ago. They are still available from case dealer. You have 8th 7th 6th 5th and high reverse on top side and 4th, 3rd, 2nd, 1st and low reverse on locer side.
caseman-d
Tim in New York
12-26-2007 15:37:24
See if you can get to this link in the archives. If you can't use the link, do a search on the forum for "shift pattern"
Link
Tim
