Case Backhoe 680ck 680e 680 Shuttle transmission problems 6
Scottt
12-24-2007 21:06:33
I'm have problems with my shuttle in a Case 680e 1977 backhoe. Does anyone have experiance working on these? I believe they are different than the 580c of the same age. I do not have a manual yet, can some email or give me there number so I could go over the options. It seems to work fine when cold then when it heats up if I shift from forward to reverse then the tractor does not move in reverse, and just barely in the forward positions. The has a slight burn smell. What is the best oil to use? When it cools down the next day it will move when cold and spin the tires when under a load? Help! If found no filters on the system. What can I do before pulling out the shuttle? What is the thickest oil I can run, I live in CA and temps are always above 45 F. Also does anyone know home many models use the same shuttle that is in the 680ck E series? Thanks!
