SC Question
J. Horn
12-23-2007 12:25:46
I know if you multiply the belt rpm by 1.44 it gives you the engine rpm (high idle @ 1760 right?), so how does one get the the belt rpm? Also, at full throttle on my SC the rpms dont get very high can I just shorten the thottle linkage or is there something else I should do?
J. Horn
12-27-2007 13:52:04
 Re: SC Question in reply to J. Horn, 12-23-2007 12:25:46
Doesn't make any noise, wondering if the actuator spring may have come of, and if so would I have to take the whole pto shaft and rear housing off to see?
J. Horn
12-23-2007 16:10:13
Also what would cause the bale lift not to work, the footswitch works, but lift doesn't move when the pto is engaged.
C. Amick
12-27-2007 09:14:07
 Re: SC Question in reply to J. Horn, 12-23-2007 16:10:13
Does it make any kind of noise, like a grinding noise? It could be a sheared key or broken chain? If there is noise, the teeth on one of the chain drive sprockets could be stripped?
