900 head gaskets
oliver77
12-21-2007 08:57:11
I have a 900 gas tractor set for pulling. It has copper head gaskets and it is seeping water. It runs about 200-220 psi. I"m looking for something composite to hold the pressure and stop the seeping. I didn"t know if you Case boys would know where to get some. I"ve already called Lubbock and they said that they don"t offer their mid-grade head gaskets anymore. Any help appreciated.
Custom King
12-23-2007 12:30:46
 Re: 900 head gaskets in reply to oliver77, 12-21-2007 08:57:11
I use copper from Clark, block is o-ringed and use silicone around water holes sent with gaskets. Torque heads, warm it up with no water in it then re torque.
tom stanley
12-22-2007 05:19:58
Oliver the old case gaskets were copper the ones I got for my 900 were composite and I got these right from case when installing new gaskets clean threads on hole and bolts I use a tap or thread chaser blow out holes with air to remove any liquid to avoid breaking block lube all of the bolt and washer use only sp hard washers torque to specs and right pattern make sure you have already installed both intake and exhaust manifolds and torque to specs before tightening heads as this alines them with the block properly then after you start unit let it warm to operating temp at least 180 let run for 15-20 minutes while still warm retorque bolts one at a time by backing off a quarter turn then retorque to spec while still warm also proper cleaning is a must and goes without saying also check flatness of both heads and block sorry to be long winded but many do not know the importance of these steps
