711b
south tx
12-20-2007 08:13:26
Is it normal that the tractor(711B) use the whole thank(33 gal LP) LP GAs in a day with the disc? I have talk to friends about their tractor and they spent a lot less with diesel.
Charles Santhuff
12-21-2007 05:52:20
 Re: 711b in reply to south tx, 12-20-2007 08:13:26
You might want to leave it LP. It is cheaper than gasoline and will probably continue to be. Cost wise you probably aren't spending much ,if any ,more than your friends.
south tx
12-21-2007 05:57:32
 Re: 711b in reply to Charles Santhuff, 12-21-2007 05:52:20
Thank you for the advise. I thought that maybe 30 Lp gallons would be to much for 7 Acres.
south tx
12-20-2007 12:11:26
Thank You. I was thinking on changing it to Gasoline since the engine can use both but why invest my holidays doing that instead I am going to plow the field.
dctom
12-20-2007 08:25:17
IM SURE IT IS, BACK IN THE DAY WHEN LP WAS POPULAR IT ONLY COST ABOUT .10 A GALLON,AND YOU COULD FILL TWICE A DAY RATHER CHEAP
south tx
12-20-2007 12:12:52
 Re: 711b in reply to dctom, 12-20-2007 08:25:17
