Case 430 3 pt hitch not working
Thomas Jones
12-19-2007 17:35:04
I have 1967 case 430. Recently the three point hitch was not lifting properly and after topping up the fluid in the torque tube it seems to have lost its ability to lift. The diverter valve under the seat has a small leak and was losing fluid. I topped up the system with hytran. I cannot seem to get pumping again. I broke the lines at the output and also before the filter to try and bleed any air out, but no luck?
Any Ideas would be greatly appreciated..
Thank you
Sincerely Tom
BarryfromIA
12-22-2007 19:00:01
 Re: Case 430 3 pt hitch not working in reply to Brian in Ohio, 12-19-2007 17:35:04
Might be good to get a manual and some fittings and a gauge and do some pressure checks.
Tom (Ks)
12-22-2007 13:39:33
 Re: Case 430 3 pt hitch not working in reply to Thomas Jones, 12-19-2007 17:35:04
The key may have broken on the pump shaft and friction may turn the pump some. The relief valve spring may be broken and you have little pressure. You will end up taking the cover off of the torque tube to find out what is wrong. I assume the rockshaft linkage did not come off (check that first). Do you have SCV's and do they work?
j Heitkemper
12-21-2007 21:08:11
Sorry Thomas , That no one has responded at this time to your problem , with all info Given if You could get a IT book for the 430 You could probably get everything working Again , Hope Others will chime in with their best suggestio n
