VAC Eagle hitch lift capacity?
Dug G.
12-19-2007 17:08:07
Does anyone know what thtte max lifting load is for a VAC? I know they use to carry two bottom plows, but not sure how much the weight is.
jdemaris
12-21-2007 12:55:51
 Re: VAC Eagle hitch lift capacity? in reply to Dug G., 12-19-2007 17:08:07
I don't know the max. weight. I've used Deere 914 twin-14" plows on mine many times, also a Deere 240 snowblower, a 5' Bush-hog, and a round-bale carrier.
I've spend a lot to time driving backwards up steep hills to prevent popping wheelies - but the only time I've maxed out the lift is when lifting wet round bales. I'm not sure what they weighed, but our bales tend to be 5-6 feet in diameter. The VAC lifts them fine dry, but has a tought time when they are soggy.
mj
12-20-2007 08:25:04
 Re: VAC Eagle hitch lift capacity? in reply to cahess, 12-19-2007 17:08:07
Dug G. said: (quoted from post at 19:08:07 12/19/07) Does anyone know what thtte max lifting load is for a VAC? I know they use to carry two bottom plows, but not sure how much the weight is.
The VA Service manual says:
third party image
For more:
Link
Jim McVay
12-19-2007 17:27:42
Alot depends on how much weight you have on the front and how far behind the liftarms the weight is. I used a 5" bushhog but the frontend would get light when going up an incline. I picked up some 530# 930 weights with a bale spear.
