case 580 ck
Duby Moore
12-18-2007 16:16:56
Hi fellas, I need to locate a good source for the guages to test the Shuttle pump,control and regulator valves (0-300 psi). And one to test the pressure from the converter (0-600) and a tach to use for the test.
this is a 1966 original 580ck. Thanks you guys are great
Scott Swinehart
12-18-2007 17:53:30
 Re: case 580 ck in reply to Duby Moore, 12-18-2007 16:16:56
Any hyd. shop should have the guages you need or a NAPA store.Either could make the hoses to perform test also.As far as a tach you may need to purchace a photo tach that picks up the reading from reflective tape.Good Luck!
Duby
12-18-2007 18:34:02
 Re: case 580 ck in reply to Scott Swinehart, 12-18-2007 17:53:30
Thanks Scott, I appreciate the help
Duby
