In the Case service manual troubleshooting: HOWLING NOISE IN DEPTH CONTROL UNIT A. Relief Valve by-passing oil �� Load may be too heavy-test pressure at the pump. In the real world, whining or howling noise is consistent with high pressure oil passing through a restricted passage. In the lift control block during the lift cycle that applies to the relief valve, the control valve and to a lesser extent the lift check valve. If you are not trying to lift an excessive load: 1. The relief valve may be lifting if the lift check valve is not opening all the way. The lift check valve is under that big plug on the bottom of the control block. It is just a ball on a spring, drop it out, check for restriction or sticking. 2. When you put the lever in the lift position the cam actuates the control valve to close the by-pass. If the lash between the cam and the control valve stem is excessive the valve will not fully close and produce the same noise as a lifting relief valve. The correct lash is .010� and adjustable with a screw. Lots of teardown to get to the adjustment, you�ll probably want to have a manual. 3. Other than that, anyone of the above 3 valves will be noisy if they are not functioning as designed, are leaking or there is debris in the oil. Joe
