800 Oil pressure
j Heitkemper
12-16-2007 20:17:16
Anyone know What is the normal Oil pressure for a 800 Diesel ? what is yours holding at ?
hunter1
12-18-2007 11:20:42
 Re: 800 Oil pressure in reply to j Heitkemper, 12-16-2007 20:17:16
When new both gas & diesel had 40 psi hot at idle.
Not any difference when started cold in the summer cannot remember winter psi when cold.
Our late model dc's had 40 psi at idle when hot.
Jim from Calif
12-17-2007 09:40:13
My '58 Case 800 diesel runs at about 50 cold and about 25 warm. It too had a new "in frame" overhaul plus a �topend� rebuild about 50 hours ago. I also installed a new Case oil pump trying to get the pressure up. The pump only improved the pressure by about 5 psi. I added two qts. of Lucas Heavy Duty Oil stabilizer which added another 5 psi when the engine is warm. (I believe the Oil Stabilizer is a good product to use in these older tractors)
J Heitkemper
12-17-2007 18:06:28
 Re: 800 Oil pressure in reply to Jim from Calif, 12-17-2007 09:40:13
Well Guys My rebuilt motor of 200 hours 25 cold ,, Dads 800, 30 years ago ran about the same , then drops off to 15 or 20 hot,, I kinda thought that was the nature of the beast ,, i will double check this with another gauge to make sure readings are in agreement,, JG has picked My interest ,, Have a DC with low pressure as Well ,, JIM IN CALIFORNIA , ,DO YOU HAVE ANY PIX OF YOUR 800 ,, NOT SURE BUT I BELIEVE I RAN ACROSS IT A WHILE BACK ,FINE LOOKING TRACTOR ., tHANX jIM
JGarner
12-18-2007 06:10:08
 Re: 800 Oil pressure in reply to J Heitkemper, 12-17-2007 18:06:28
Jim, I think I remember our 53 SC running about 30 when cold, 20 or so at hot idle and up to 30-40 at plow pulling RPM (it didn't have a lot of hours on it and Dad bought it new). Dad was a large engine mechanic by trade (Humble Oil and Refining Co.) and was meticulous about maintenance.
I don't think the older units had pressures as high as modern engines. Also what oil are you using, the older ones weren't made for multi viscosity oils? I am going to run straight 30wt in my 630 as long as I can get it. Straight weight oils are getting harder to find.
JGarner
J Heitkemper
12-18-2007 09:46:05
 Re: 800 Oil pressure in reply to JGarner, 12-18-2007 06:10:08
15 W 40 ROTELLA and a little Lucas to Slick her up GOood., My 4020 runs from 15 at idle to 28 full throttle under load , JD folks say that is plenty , and normal ,, Also tell me to expect the Jd normally to use a qt of oil per 10 hour hard work day ..... .These Low oil pressures Make Me Nervous ,,.Jim
JGarner
12-18-2007 11:30:01
 Re: 800 Oil pressure in reply to J Heitkemper, 12-18-2007 09:46:05
We used to use Rotella almost exclusively in all our engines, Gas and Diesel with no problems (30wt) but now with the new multi vis oils out I am seeing posts here that say not to use it in the older engines but for the life of me I don't understand why. I may do just that in the 630, shouldn't be much different that running straight 30wt Castrol (all I could get last time, I usually run Texaco Havoline in everything). Also, Sam's sells it in gallon jugs at a good price too!! What you think about STP for added slick and viscosity enhancer? I have not had that much experience with Lucas. Although their gear lube has stopped the bearing housing from leaking (weeping) on the 630 brake section. I think I nicked an o-ring putting it back together.
Jim from Calif
12-17-2007 20:50:02
Jim; Just go to the WEBSHOTS link to view my pix. Link
JGarner
12-17-2007 06:43:07
Jim I feel your pain. (< :
JGarner
Gene Dotson
12-17-2007 04:01:56
30 PSI max on my 700 diesel. 15 PSI idling hot. The massive bearings in these engines don't require much oil pressure... Gene
Jim B
12-16-2007 21:10:36
50-60 PSI when warmed up.
Rebuilt Bottom end, Sleeves, Rings & Valve Job about 500 hours ago.
Also replaced clutch plates in the COM converter lock-up & master clutch at the same time. No, yes I said NO, gear grinding since. And the old plates didn't look too badly worn or warped at all. I was surprised.
