More on the Sc
36 A
12-16-2007 18:51:35
The tractor was in a woods for about ten years and stuck.One rear wheel stuck flat.Tractor belongs to one neighbor and is in another neighbors shop.We up it in saturday morning and its good and warmed up now.I loosened the four bigger bolts on the break and the tire moves look in to that later.The motor we started rocking and by gollie so did the fan,in no time we could ture it all the way around.Have to have some luck knock on wood.till next time 36 A
C. Amick
12-17-2007 09:04:33
 Re: More on the Sc in reply to 36 A, 12-16-2007 18:51:35
You may have bent some push rods if you turned the engine over without first making sure all the valves were free. Of course, the push rods can be straightened.
36 A
12-17-2007 18:04:06
 Re: More on the Sc in reply to C. Amick, 12-17-2007 09:04:33
Thanks we checked them first
C. Amick
12-19-2007 09:28:45
 Re: More on the Sc in reply to 36 A, 12-17-2007 18:04:06
Sounds like you know what you are doing. I ended up having to replace the piston rings on the last one I worked on that had been sitting like that. The rings were stuck to the pistons and it smoked. Usually the water pump seal goes bad as well.
