Case VAC Engine Mounted Hydraulic Pump
Roen C
12-16-2007 09:51:55
I have a Case VAC with an engine mounted hydraulic pump, I can find the belt pulley pumps everywhere, but no rebuilts for this one, I posted a reply on seals thinking I could replace them if I could get the right seals? Is type system less common or not originally manufacured very long?
Farmer Jack
12-16-2007 12:07:18
 Re: Case VAC Engine Mounted Hydraulic Pump in reply to Roen C, 12-16-2007 09:51:55
they were the pump used with all models having the Eagle hitch, so they are quite common and are on Ebay quite a bit. Seals? You probably can still get them from CNH.
Roen C
12-17-2007 08:51:21
 Re: Case VAC Engine Mounted Hydraulic Pump in reply to Farmer Jack, 12-16-2007 12:07:18
Thanks for the info, also Paul f writes, "There is only one oil seal in the pump if you have a distributor ignition. Case # was O4244AB replaced by G105700 that crosses to CR 6229".
