vac hydraulic problems
johnny5
12-16-2007 09:28:46
we are having problems with the hydraulic valve mounted under the pulley housing. Initially the lift cylinder was leaking oil out of the seal. The replacement has helped but not solved the lift arms lifting capabilities. With out a load on the arms, it will lift but when a load is applied it tries but will not lift. We took the valve apart and found only one steel ball in the assembly which we installed a new one and still it does not work. The brass bleeder valve when opened pulsates with a small amount of oil. As I am posting this I am wondering about air in the system. The serial number is vac5364984. Thank you
C. Amick
12-16-2007 15:15:25
 Re: vac hydraulic problems in reply to johnny5, 12-16-2007 09:28:46
Did you push the control lever to the "up" position when you had the bleeder valve open? You may have to raise the hoist 2 or 3 times with the bleeder open to work all the air out, if that's the problem.
johnny5
12-16-2007 20:10:54
 Re: vac hydraulic problems in reply to C. Amick, 12-16-2007 15:15:25
Thanks for the reply! I had the lever in both positions when trying to bleed it. But, when reading your reply you got me thinking, correct me if I"m wrong, the bleeder should be open when lifting which would be pressurizing the cylinder and closed when lowering and the oil returning to tank.
C. Amick
12-17-2007 06:19:54
 Re: vac hydraulic problems in reply to johnny5, 12-16-2007 20:10:54
Yes, that seems correct.
