Hydraulic Pump Seals for Case VAC
Roen C
12-16-2007 09:17:11
This message is a reply to an archived post by Paul f on October 18, 2004 at 15:00:53.
The original subject was "Seals for VAC and DC".
Sure appreciate the seal info, I have a Case VAC and a Case S, I can't find much on the VAC hydraulic pump (engine mounted, not belt pulley type). My VAC has leaking hydraulic pump seals, any thoughts?
Paul f
12-17-2007 05:43:28
 Re: Hydraulic Pump Seals for Case VAC in reply to Roen C, 12-16-2007 09:17:11
There is only one oil seal in the pump if you have a distributor ignition.
Case # was O4244AB replaced by G105700 that crosses to CR 6229
Roen C
12-22-2007 15:42:44
 Re: Hydraulic Pump Seals for Case VAC in reply to Paul f, 12-17-2007 05:43:28
I went by cse in Weatherford TX and they will have me a seal in by next Friday, Thanks
Roen C
Roen C
12-17-2007 08:34:15
Thanks so much for the help, I had looked on line for rebuilts, I could find the belt pulley mounted type several places but no source for the front engine mounted. Case here in Ft Worth listed all the original part numbers in their books but only as an out of production part,
Roen
watsosngotit
12-16-2007 14:23:01
All the seals for the hydraulic pump are available through Napa. If you have a local bearing shop you could also get them there.
Roen C
12-17-2007 08:43:57
 Re: Hydraulic Pump Seals for Case VAC in reply to watsosngotit, 12-16-2007 14:23:01
Thanks so much for the help, I'll check with NAPA and see what I can find.
Also Paul f replied, "There is only one oil seal in the pump if you have a distributor ignition.
Case # was O4244AB replaced by G105700 that crosses to CR 6229".
